Unable to monitor amount downloaded
- My Account/Billing
- Unable to monitor amount downloaded
18-03-2012 9:59 AM
My broadband went live yesterday and I was astonished to get a text warning me that I'd already used 6GB on the same day. I'm still unable to monitor my usage, presumably because I'm a new customer.
Could someone at PN look into this for me please as it's quite worrying?
Re: Unable to monitor amount downloaded
18-03-2012 11:51 AM
18-03-2012 12:09 PM
Quote from: polygor38 I'm still unable to monitor my usage, presumably because I'm a new customer.
I've never heard of this before. What do you get when you go to https://portal.plus.net/view_my_broadband_usage/index.php
18-03-2012 1:30 PM
"Sorry, there's nothing to show at the moment.
This might be because your account is new, or your usage has been reset for a new billing period.
It can take up to 2 hours for your usage to show up - please try again later."
18-03-2012 1:32 PM
Quote from: Strat In the meantime you could use something like this to monitor usage...http://www.softperfect.com/products/networx/
Thanks for the link. I need to monitor another PC, so I imagine it would mean having to keep mine running constantly.
18-03-2012 1:46 PM
it gives you an houry, daily, weekly, on peak and off peak usage, up and down.
18-03-2012 2:08 PM
18-03-2012 2:12 PM
Pierré's suggested setup is probably preferred.
18-03-2012 2:21 PM
I'm still unsure if this is going to record all usage, hence my appeal to PN staff to look at my query.
18-03-2012 2:26 PM
Each machine logs it's own usage and then shares it whenever they are both on at the same time, so there is no need to keep one machine on.
18-03-2012 2:26 PM
18-03-2012 2:28 PM
18-03-2012 4:05 PM
18-03-2012 8:08 PM
Quote from: polygor38 Just checked again...
I get the same message.
I raised a support ticket & got the following response.
Quote I have added your account to an internal problem (69949) which has been raised to investigate the cause of your view my usage not working correctly.
I think only certain accounts are affected, but I've no idea which ones or why.
P.S. That was on 12th March & it's still the same today.
19-03-2012 7:51 AM
