Unable to login to Portal (04/01/2017)
anothername
Last night a holding page was served saying that the portal was undergoing maintenance.
This morning although normal login prompts are showing, I am unable to login, with  "invalid username or password" being returned.
Nothing's changed at my end.
I can't "raise a ticket" of course as I can't login.
Yes, I have cleared cache and cookies and all that stuff.
(Also very annoying is that I can't login to the community using my old community login/passwd combination any more as that doesn't seem to be recognised either, and a password reset request hasn't resulted in a reset email. So I've had to make another community login just to post this)
anniesboy
Re: Unable to login to Portal (04/01/2017)
Same with me
Fixes: 167
We're looking in to this: https://community.plus.net/t5/Service-Status/Website-and-Internal-Systems-NEW/td-p/1401146
 Chris Parr
 Plusnet Staff
MadScientist
I'm suddenly having problems with sending emails as well.  Is this  a related issue?
thanks Chris.
But I thought the days when PN changed things and then sent them live without testing them properly (or at all) were long gone Cool smiley
paulh (temporarily anothername)
[Still, I fixed the community login problem. For some bizarre reason I had the email set to something other than a PN address.]
jamesbee
ditto here 04-01-17 10:30
Plusnet Staff
Plusnet Staff
Fixes: 6
Hi @jamesbee, thanks for contacting on the forum.
We're still working with our engineering teams to resolve the issues. Unfortunately I cannot provide an ERT at the moment but it's being worked on as we speak. Please bear with us.
Regards,
Mark
 Mark Duell
 Plusnet Support
22:07 04/01/2017
Stiill unable to login.
mort7890
Just logged in with no problem, reboot router and try again.
Can't see what a router  has to with a portal access problem
08:35 05/01/17 - working OK again now
(no reboots required)
Plusnet Staff
Plusnet Staff
Fixes: 6
Glad it's working again @paulh.
Regards,
Mark
 Mark Duell
 Plusnet Support
