Un-answered calls to mobiles being charged
manofkent1
I am on Unlimited UK & Mobile  tariff for home phone.  When I called my mobile (not Plusnet) to locate it I was charged 12p because I did not answer, just hung up.  If I had answered it would have been free.
WHY?
6 REPLIES 6
Fixes: 460
Re: Un-answered calls to mobiles being charged
@manofkent1
How long was it ringing? Could it have been in the process of switching to answerphone just as you rang off?
manofkent1
Unlikely.  It has happened 3 times,  and it probably should not have been charged if it did go to answer phone.  Calls to mobiles are free.
Fixes: 237
I started to do some research on this subject earlier today and reached the conclusion that it's all very unclear.  Ofcom has a number of papers on Wholesale Call Termination Charges, specifically fixed line to mobile.
Back in 2004 this was covered by condition MC3, in 2011 this was referred to as condition M3 and were substantially the same, no charge where ...
  1. Terminating network cannot connect the call (network fault)
  2. Terminating network cannot route the call (phone off no answering service)
  3. Routed call is not answered (no answering service active)
I found reference to a change in Ofcom rules which permit charges to be raised at the point that a call is accepted into the terminating network in recognition that there are costs incurred in the facilitation of call routing, however I could not find an authoritative source.  Searching Ofcom papers is a nightmare!!
This has been raised before and IIRC there was some insurance that if calls are part routed by voip they are deemed "answered" at The point of touching the VoIP network.  That said, if one's service has included mobile calls and the FUP allowance has not been exceeded then there should be no charge!!!
I have added this consideration to another discussion on information covering call charging practices.
manofkent1
Thanks for the research.
I think I will raise it direct with Billing.
In future I will make sure I Answer the call (no charge).
Aren't things complicated, and its only 12p.
willcutforth
Fixes: 113
Hey @manofkent1 can you pop me over your username via PM and I will sort this out for you Smiley
 Will Cutforth
Fixes: 237
Send a Personal Message
Support staff might ask for private information to be sent via a Personal Message (PM) which new users might not know how to do. Further to that, new users might not have attained sufficient ranking to send PMs:-
  • Have made 5 or more posts
  • Have logged in (and out) at least twice and made 3 posts
Having attained the ranking a PM is sent as follows:-
  1. Click on the staff member's name in the left panel
  2. Click on SEND PRIVATE MESSAGE on the right
Note that PMs sent to one staff member are visible to all staff members to provide support continuity across working rosters.
