There is a scheduled product change in place
SpicyPineapple
I want to set up a new direct debit but I keep getting the above error message so I can't do anything to my account. The product change was a contract renewal that has already been completed and I've had at least one 'clean' bill (no pro rata, no new equipment or fancy charges etc) on the new contract since then. Is there a way someone can remove this block from my account so I can have control of my billing method again? Or if not, can you tell me when it will be automatically lifted? Thanks
5 REPLIES 5
Fixes: 334
Re: There is a scheduled product change in place
@SpicyPineapple Hopefully one of the Help Team will be along fairly soon and manually sort this for you. It is an unfortunate 'feature' of the 'new' accounts platform that this flag is correctly raised during a change, and it should be automatically cleared when all changes are complete - unfortunately it isn't, and only manual intervention can clear it.
SpicyPineapple
Thanks @jab1 for the explanation, that's really helpful to know 😊
SammyM
Fixes: 101
Hiya @SpicyPineapple
I'm sorry you are having this issue and I know what a hassle it can cause.
I think I have found and fix the problem, can you try again now and see if that message has gone?
 Sammy M - Sheffield Team
SpicyPineapple
Yes, that worked. Thanks for the quick help!
SammyM
Fixes: 101
Yay fantastic, have a lovely week!!
