The Referal letter Wording
- My Account/Billing
- The Referal letter Wording
09-06-2008 10:41 AM
Just done another referral and noticed that the letter indicates 8 rather than 15 in the
amount of usage.
Is the 15 now not a standard for Option 2 ?
amount of usage.
Message 1 of 8
(4,063 Views)
7 REPLIES 7
Re: The Referal letter Wording
09-06-2008 10:56 AM
Would you mind showing me the text of the letter that you're referring to?
I had a look on your account and couldn't see any reference to the 8GB product.
Message 2 of 8
(831 Views)
09-06-2008 5:11 PM
If you visit the portal and hit the 'Make a referral' link on the lower left sidebar, after entering an email address and recipient name etc, the system generates a message with referral link to send.
If you choose the BBYW Option 2 product to recommend, the system populates the message with the old usage limits.
Presumably this applies for all the products, I only checked one of them.
Message 3 of 8
(831 Views)
10-06-2008 4:31 PM
Thanks.
What you have found is the same as my query.
Are there plans to update the information ?
I would assume so, but it may be an oversight.
Message 4 of 8
(831 Views)
10-06-2008 4:57 PM
I can only presume its an oversight and will be rectified shortly. Shouldn't take the content guys too long to alter it methinks.
Message 5 of 8
(831 Views)
13-06-2008 3:28 PM
Hi guys,
I have raised a problem on this with the content team- appears to be an oversight as there are often many pages to update when things are changed.
Thanks for pointing it out, it will be prioritised and fixed asap.
Amy
Amy
Message 6 of 8
(831 Views)
17-06-2008 10:57 AM
This problem is now fixed.
Usage figures are now up to date and Option 4 has been removed from the dropdown list.
Message 7 of 8
(831 Views)
17-06-2008 11:28 AM
Content team FTW!
Message 8 of 8
(831 Views)
