Switching provider
Fixes: 116
Re: Switching provider
@Staffy100
If I understand correctly once OR have accepted the order and confirmed an install date you get the option of delaying this to a later date that suits you (you need to be present for the install).
If you get a reasonable quick date I would consider delaying until 9 or 10 days before the end of your contract. This means that, all things being well, the PN system will know you're leaving and will not generate a full months bill at out of contract rates. The bill is generated 7 days in advance of the billing date.
Fixes: 579
@bmc
It doesnt work like that I'm afraid. Leaving dates can change, so until leaving actually happens, billing continues as normal (monthly in advance). Around 21 days after leaving , a final bill is generated taking into account any refund due.
Staffy100
Thanks for the heads up about a potential delay with OR @markhawkin . Will get this going!
