Supplied MAC code out of date?
stan4th
I have just been on the phone to BT to get MAC code and after they had all sorts of problems (25 mins) with the computer he finally me a code . However, when I entered it it says its out of date.
Any ideas?
Was on ADSL moving to Fibre with Plusnet
giscott
Re: Supplied MAC code out of date?
You're lucky you were even given a code on the phone. Usually when you request one they email/text it within 5 days.
It took nearly 5 weeks to get mine! The root of the problem seemed to be that because I had requested a MAC within the last 24 months (but decided not to use it to move away) it caused their system to throw a wobbly and issue me the same one. They then had difficulty issuing me a new one.
Just keep on at the MAC people. Which is a pain, cos they're actually a retentions team that want to offer you a deal every time you phone them.
RealAleMadrid
Aspiring Champion
Fixes: 17
Surely this is BT's problem and nothing to do with PlusNet. BT need to provide a valid MAC.
giscott
I should point out that my reply relates to my experience with BT and getting a MAC from them.
sjptd
Yes, but worth posting here because there might well be others with similar experiences who can make helpful suggestions.
Fixes: 167
@stan4th
Can you PM me the MAC you've been given please? I'll try it manually from here for you.
 Chris Parr
 Plusnet Staff
stan4th
if I am moving from ADSL to Fibre do I need a MAC code?
stan4th
Just to let you know; I called BT again and finally after trying to find me an offer to persuade me to stay, I would have to wait the 30 days to create another and it not working on his computer, I got them to generate another one - and it worked!
Smiley
MattyC
Champion
Fixes: 46
That's a relief.
I've arranged for someone in provisioning to place your order for you.
Matty
