Still confused by bill
Sir_Lurkalot
Hi
Queried last month why my call charges were not being taken off my credit.  Was told it had been resolved.
So why am I due to be charged £23.63 this month ?
Presuming I am already going to be charged at the new rate,
that's £11.99 phone + £11.49 BB =  £ 23.48
I have £9 + of call credit, so why am I not just being charged the two basic rentals?
This figure has reduced slightly from last month, so *some* calls are registering against the credit.
I can see these extra few pence each month, purely because I have such a low call rate.
What's to say there are not lots of people having this added to their bill ?
Username rover2000
Fixes: 61
Re: Still confused by bill
Hi Sir Lurkalot,
I've just had a look at your account. I'd advise having a look at your itemised bill as the credit seems to have been used up for some calls yet others have been charged for. I'll arrange a refund for you. With regards to the processing of call charges we are having a separate issue with that running behind at the moment so I'll check your calls against that data when the systems have caught up.
Adam
 Adam Walker
Sir_Lurkalot
Hi Adam
Thanks for the prompt reply.
It would just be much more straight-forward and easier to keep check if *all* call charges were taken from any available credit,
so that the monthly DD was predictable, which is what I would prefer.  Perhaps it is something that could be looked into ?
Cheers
Fixes: 61
Sure, I'll make sure this gets some attention. I'll report back tomorrow.
Adam.
 Adam Walker
Fixes: 81
Quote from: _Adam_Walker_
This is the way the system is designed.
Calls are always marked as chargeable unless excess credit is available *at the time the calls were made* (as opposed to your billing date).
e.g. You make £10 worth of calls and then top up by £10. In this instance you get charged for the calls when you are billed and the credit is rolled over to the next month.
e.g. The next month you make £10 worth of calls but are £10 above your credit limit due to the previous month's top-up. In this instance you are not charged for the calls but your available credit is reduced by £10.
Does that make sense?
To be honest, I can understand why you're confused by this. Especially given the (lacking/inaccurate) explanation on this page.
I'll have a word with our content guys and get that page updated...
Edit: problem 65237 raised to correct the support page content.
Fixes: 81
Quote from: Bob
Better late than never, the content on the above page has now been updated.
