Speed tester
- My Account/Billing
- Speed tester
Speed tester
11-08-2007 11:17 AM
Keep it simple please.
Re: Speed tester
11-08-2007 11:25 AM
Re: Speed tester
11-08-2007 12:26 PM
Re: Speed tester
11-08-2007 1:05 PM
Re: Speed tester
12-08-2007 3:46 PM
Quote from: Bob The new one at http://www.mybroadbandspeed.co.uk/
I'm seeing a different one in 'connection settings'. Where is it located?
Re: Speed tester
12-08-2007 6:00 PM
Quote from: artmo
Just click on ----
and you will find it.
Re: Speed tester
13-08-2007 9:50 AM
I'll give the relevant people a nudge and see if we have a date for the go-live.
Re: Speed tester
13-08-2007 12:10 PM
Thanks for the reply, I note that the blog you indicated said that the old speedtester didn't take account of some of the later firewalls etc.
I have found that the new speedtester doesn't like the ZoneAlarm Security Suite that I use, which is version 7.0.362.000.
When I turn off the ZoneAlarm all seems OK and the speedtaster seems to be alright. I'm afraid that I'm not clever enough to change the firewall settings to make it fit and I might mess up everything by operating in the dark.
I'm sorry if I shouldn't have been trying the new speedtester, in fact I can't remember how I found it.
When PlusNet brings it into service I hope it will be heralded with some sort of announcement which is easily found by everyone and not just the experts.
In the meantime will anyone be able to tell me what to do with the ZoneAlarm. ------- careful now!!!!
Re: Speed tester
13-08-2007 7:24 PM
I do have my router IP address (and in fact the whole DHCP client range) in the Trusted Zone. Whether that is needed I'm not sure, I entered this so my computers could speak to each other unhindered.
I use AVG free antivirus.
Re: Speed tester
13-08-2007 7:35 PM
Quote from: spraxyt I don't have the full ZoneAlarm Security Suite, just the Firewall freebie which is version 7.0.337.000. I've not had any problems with accessing and using the new speedtester.
As I tried to indicate I'm a little ignorant--------
Would you be able to tell me how to do what you've done please?
Thanks.
Re: Speed tester
13-08-2007 8:12 PM
Quote from: Bob Would you be able to tell me how to do what you've done please?
Assuming the interface is similar for the full program suite.
Click on Firewall in the left-hand column.
This shows a Main tab where the top slider (Internet Zone Security) is set to High, and the lower slider (Trusted Zone Security) is set to Medium.
Click the second tab Zones to show settings applicable for each of the Internet and Trusted zones.
Click the Add>> button (bottom right) to add settings and select IP Range in the drop-down list.
In the dialogue that opens up, Zone should be Trusted, the first IP Address 192.168.1.1, second IP Address 192.168.1.100 (or whatever IP range your router uses). Entering Router DHCP Clients as the Description is suggested unless you prefer a different one.
Re: Speed tester
16-08-2007 4:24 PM
