Signup strangeness?
matt_2k34
Signup strangeness?
Hi all
Didnt quite know where to post this, however this will do as its to do with the signup process...
Just trying to sign up a friend  Wink and if you view the attachment, the top right window "live chat" actually takes you to a BT livechat, with BT Business...
Is this normal / correct? seems odd that after starting the sign up process, that you let people take advice from BT...?
Regards
jojopillo
Re: Signup strangeness?
Hi Matt_2k34,
Can you clear your cookies and try again?
Jojo Smiley
matt_2k34
Ahh, so its becaues i'd been poking around on packages on BT's site too?
If thats the case, i think one of the web devs should fix that so it *only* goes to a PN chat, afterall anyone signing up will be shopping around for the best deal and wont clear cookies prior to doing so..?
Regards
jojopillo
Cheers for the heads up there Matt Smiley
