Reward card is a lie
Fixes: 160
Re: Reward card is a lie
Is there some risk of confusion here?
  • Plusnet referred to TWO phone numbers
  • Plusnet said that one is eligible for the reward card, the other is not
  • Is there any possibility that the user is struggling here because they are trying to place their claim against the number reported to be not eligible?
  • Has the user made a claim (and successfully received their reward card) in respect of the number which is eligable?
AJ0704
Hi MoR - yes, I've NOT had a reward card sent through; or at least it hasn't arrived at my home address, which is why I rang Black Hawk in the first place and they said that they hadn't received anything from Plusnet.
Looks like you are getting the run-around too!  Frustrating, isn't it?
Could you go back to Black Hawk please?
Thank you
Kind regards
Adrian
Dumbledore
Fixes: 34
Hello @AJ0704 I am sorry that you are being re-directing to ourselves from Blackhawk and vice versa.
I have sent an email to our Mobile operations Team, requesting assistance with regards to this on-going issue. I have forwarded your response to the department, hopefully, they can shed some light into this. I do apologise for the inconvenience caused by this, we appreciate your continued patience.
Kind regards.
AJ0704
Any news yet?
I will be unavailable all of next week - but will check back upon my return.  Hope to hear something positive very soon.
Adrian
EmilyD
Fixes: 117
Hi @AJ0704,
Thank you for getting back in touch, I'm sorry that you've not received an update yet. Our mobile operations team have discussed this with Blackhawk and say that Blackhawk have advised that you have successfully redeemed the cashback and that it is on its way to you.
As you have mentioned that Blackhawk have told you that they have no record of your claim, we'll need to investigate this further. Please can you confirm the date that you completed the cashback redemption email? We will then send this back to our operations team and they will investigate this further.
 Emily D
