Return Router Address
Plusnet have sent me two routers! How do I send back the one I don't need?
4 REPLIES 4
Fixes: 963
Re: Return Router Address
I'm not entirely sure why two routers were dispatched. We've only ordered one. No worries though, I've sent you a returns bag which you should receive within a few days - that way you can return it without incurring any postage fees.
Cheers
Fixes: 62
@Gandalf,
Given the choice of two routers to return, can you guide the OP to the one which is not registered to their account ... and identify the account to which it is registered and resolve there too.
One would not want auto configuration applying the wrong account details leading to usage being ascribed to the wrong user ... or worse still causing connection conflicts if said account had a fixed IP address.
I was sent the first router due to an error with Plusnet. It's a larger router and the account has been cancelled. That's the one I will be returning.
Fixes: 963
Thanks for the clarification, I'm seeing that now. I originally assumed that our warehouse had dispatched two routers from one order - that's been known to happen occasionally.
