Restricted speed by HOW MUCH !!!
mathewlisett
ok, im experirenced in this area enough to know download speeds when capped go from say 7/mb to say 2/mb
so i knew it was going to happen today as were at 10.4gb.
but WOW its gone from 7.6mb to 0.26kb/s
thats less than the up speed.
is this normal, or is this just part of the setting in stage of the new line?
as i feel this is simply drastic
10 REPLIES 10
Chris
Legend
Fixes: 169
Re: Restricted speed by HOW MUCH !!!
If you've reached the usage allowance set on your account, without any additional usage being paid for, then your line is restricted down to 256kb/s. Take a look at this page for the information on this and the options you have: http://www.plus.net/support/broadband/products/res_broadband_faq.shtml#overAllowance
Oldjim
Resting Legend
Fixes: 63
That is absolutely normal.
if you want to get more speed you will need to add extra usage.
This is on the assumption that you are on Value and have set a price cap so that you don't pay extra. If you haven't just ignore me  Lips_are_sealed
jelv
Fixes: 10
On some other suppliers you wouldn't be able to use your connection at all when you reached your usage limit. Just be thankful that you can still do the essential tasks such as emails or on-line banking (albeit very slowly).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mathewlisett
ok, didnt know that.
ok next question, the free usuage time period. does the speed stay the same or go back to the higher speeds?
Oldjim
Resting Legend
Fixes: 63
Stay the same
Just to add - the upstream is heavily throttled as well
mathewlisett
so to clarify, the free usuage will stay at the restricted speed , just any usuage is free.
really wishing i hadnt downloaded the episodes during the evening on the first daay and just waited for midnight .
Oldjim
Resting Legend
Fixes: 63
correct
If you have a long time to go until your usage gets rest it may be worth biting the bullet and adding £5 to your limit for this month only
mathewlisett
thats what i was thinking
mathewlisett
right ok just bit the bullet so to speak, and did an extra £5 for this month.  so my querie is when does is take effect?
edit:
seems it takes less than the time it took for the page to load here and type my question lol.
i did a speed check with speedtest and my question was answered Smiley all good
Oldjim
Resting Legend
Fixes: 63
I have no idea but would be worth a phone call if it doesn't happen almost  immediately (under 30 minutes)
