Reopening a closed support ticket - possible?
AJones
My ongoing support ticket (over two months!) has been closed, although the problem still exists.  If I want to pursue this further, is there any way I can continue with the same support ticket or do I have to start again from scratch?
Fixes: 79
Re: Reopening a closed support ticket - possible?
Unfortunately that isn't possible but that does not mean to say that we can't go on helping you with the same issue. The best thing to do is either contact us by phone or raise a new ticket quoting the ID of the old ticket.
If you let us know on here once you've done this I can make sure that the information on the closed ticket is not overlooked.
 Adam Walker
AJones
Thanks.  I've just raised a new fault, #42367489.  The original ticket was #40023273.
Fixes: 79
Sorry about the delayed reply, I've just looked at your ticket and can see that we just need to arrange an engineer visit as the next step. Please shout up here if you have any difficulties dealing with us in relation to this and I'll get straight on the case.
Adam.
 Adam Walker
