Referrals
- My Account/Billing
- Referrals
Re: Referrals
10-08-2015 2:52 PM
I'm not complaining but do wish that it was put in to plain English or that that there's a glossary of these things so I don't look like a plonker.
Many thanks for the time and trouble to help me on that, and the same to all other Plusnet staff, mods, posters and readers.
wallzone
Re: Referrals
10-08-2015 2:56 PM
Re: Referrals
10-08-2015 3:12 PM
Re: Referrals
10-08-2015 3:20 PM
I've made a mental note to ask to be downgraded to a 'generic services' account rather than a 'free account' in December.
Re: Referrals
10-08-2015 3:21 PM
Re: Referrals
10-08-2015 3:39 PM
Regards
Mike
Re: Referrals
13-08-2015 9:20 AM
Now considering I can login to post with the same password I imagine it must be something at your side Plusnet, or is it part of this account?
If so would you please check up how much is going to be owed then I may stop the DD at the bank please after the final one is removed, though I will never know as I cannot check the emails from you to confirm if the amount is correct or not?
Many thanks indeed.
wallzone.
Re: Referrals
13-08-2015 9:25 AM
Re: Referrals
13-08-2015 10:05 AM
Also as i said I want to kill the DD but you can guarantee if I do know it will be too soon and they will not be able to get what I owe them, and I have ALL 08 and private numbers blocked on LL so they will struggle to contact me, hence why I assumed email or account details would be best.
Thanks for the quick reply also Oldjim.
wallzone.
Re: Referrals
13-08-2015 10:17 AM
So, either the change was screwed up or the GSA Account is useless as you can't check anything including the referrals you are due
Re: Referrals
13-08-2015 10:40 AM
Thanks again Oldjim.
wallzone.
Re: Referrals
13-08-2015 9:16 PM
Many thanks to whoever you may be.
wallzone.
Re: Referrals
13-08-2015 10:54 PM
AIUI the only part of Plusnet that can give you the free account is the COT (Customer Options Team). But not all of them are necessarily up to speed on this question. As you can see from the quote, the agent I spoke to had to go away and check. His initial reaction was that when I left, my account would be completely closed once any refund of subscription due had been refunded through my d/d. I don't think he even knew about the £20 for email system retention. (I think that £20 for ongoing email services is perfectly legitimate - all non-free hosts charge something).
The approach I used after that first reply was exactly as I described in the quote.
I had to wait almost exactly 30 minutes for someone to answer, but it is an 0800 so should now be free from your mobile.
I called again today, as my migration took place at 01:30 this morning. I wanted to be sure I was being/had been moved to a free account. Again, almost exactly 30 minutes wait. (In each case the auto-forecast was 15 minutes). Plusnet still had not had notification from "their suppliers" (LOL) that I had migrated. Which has to be rubbish - as with so many migrations in where the account hasn't been fully activated.
The agent confirmed he could see the note left on the account about the change to "free". I asked if I would get an email notification when that happened and he said yes.
I reckon I should be OK.
The COT number is 0800 073 3057. They also give 0330 123 0178 from a mobile, which was of course needed before 0800 from mobiles became free. "Between 8am-8pm Monday-Friday or 9am-7pm on Saturdays and 9am-6pm on Sundays".
I hope that helps. Oh, and I didn't get heated at all when the first agent needed me to go into that detail. It's not the fault of any agent there or here when they haven't been properly briefed about this sort of thing. IMO it shouldn't even be a support (here) or COT (there) matter. It should be a simple, bog-standard, automatic operation in Accounts. But of course, then Plusnet wouldn't get out of paying it.
Re: Referrals
14-08-2015 8:34 AM
Still awaiting some help or information from Plusnet staff please re this.
wallzone.
Re: Referrals
14-08-2015 8:38 AM
Basically even though I'd already performed the account change, when the phone was removed it closed your account down. I've reopened it as a free account and you should be able to log in and view your referrals.
