Referral credits - odd amounts
ciderboy
For the last three months my referral credit has changed from £2.50 per month (not a lot - but it all helps) to £1.99 per month.
How is this calculated? Has something changed that I'm not aware of?
6 REPLIES 6
Fixes: 1,483
Re: Referral credits - odd amounts
it's possible one of your referrals has left pn or change package - you can see the breakdown here https://www.plus.net/my.html?action=mydiscount_static_info&r_action=Current_Referrals
ciderboy
Thanks for that - unfortunately it's showing that I should still be getting £2.50.
Fixes: 395
Have you got a discount on your Broadband subscription ( i.e without the phone component )  which brings the price down to £1.99 ?
Referral credits are only applied to the BB part of the subs each month. Any excess will be accumulated until it gets to £5 and then it will be credited back to the bank account used for your Direct debit.
ciderboy
Ah - that explains it.
Many thanks.
Fixes: 395
No problem. There's probably only a few of us who've been around long enough to undertsand how the referral system works.
In your case it's going to take about 10 months till you get the £5. Set yourself a reminder somewhere to go and check, because sometimes the system can need a 'prod' to get it to paySmiley.
Fixes: 1,600
Hi there. Thanks for getting in touch with us via our community forums.
@MisterW is correct in that referral credits are only redeemed against the broadband subscription charges, and once the unused referral credits build up to £5 we'll send it back to your a direct debit where one is active, or by cheque.
Please let us know if you have any further queries.
Anoush
