Question #36610381- Exchange has BT, AOL & TalkTalk. Does this make it Market 3?
Wheel_nut
One of my Referral Accounts is on thw WSGRE Exchange which is showing AOL and TalkTalk LLU sercices available in addition to BT.
Does this make it Market 3 and if so, will the lower Tariff be applied automatically?
See  Question #36610381
pierre_pierre
Re: Question #36610381- Exchange has BT, AOL & TalkTalk. Does this make it Market 3?
no its market two, you have to have four LLU  see http://www.samknows.com/broadband/exchange/WSGRE
Wheel_nut
Bummer! I think that Hell will freeze over before any of the exchanges in this district are enabled for FOUR LLu suppliers!
Thanks for the information Pierre-Pierre  Cry
pierre_pierre
Well I had a good overnight stay in the Holiday Inn on the way up to Skye
