Question 214243040 & Email reference: EPN0161
PeeGee
These both refer to the approaching end of my LRS at the next billing date. However, they differ in the amount I will pay until the end of my current contract in December. I would appreciate clarification about this - which can be appended to the Question (I am not able to respond to it).
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
6 REPLIES 6
Fixes: 1,578
Re: Question 214243040 & Email reference: EPN0161
Thanks for your post @PeeGee
Sorry for the confusion. I can't add a comment to the question 214243040 as that was created as a closed ticket to send an email so I've created a new ticket under ref 214348503 with some clarification.
Let me know if you've got any further queries.
PeeGee
@Gandalf Thanks for your prompt reply confirming what I thought the situation should be.
Phil
Fixes: 1,578
Cool. No problem at all Phil, let me know if there's anything else you'd need help with
PeeGee
@Gandalf Minor problem - the tickets are closed and the billing e-mail (just received) has the wrong amount. It may be a "left hand/right hand" problem, so no action needed otherwise it can be sorted before the next bill.
BD
Fixes: 86
Hi @PeeGee, thanks for getting back to us and I'm sorry to hear the latest invoice amount has come as a shock. I've looked into this for you and although I can't confirm my findings on here, I've raised a ticket on your account with further information that can be seen here.
I hope this helps.
PeeGee
@BD Thanks for the clarification.
