Product Upgrade
- My Account/Billing
- Re: Product Upgrade
Product Upgrade
04-05-2019 12:28 PM
I had an email the other day saying that my upgrade to fibre extra had completed. I've disconnected and reconnected but there is no evidence that the upgrade has completed so was wondering when does the upgrade actually take place.
Re: Product Upgrade
04-05-2019 1:05 PM
Hi @rhohne, thanks for getting in touch.
Sorry to hear you've received an email advising your upgrade order is complete. I've taken a look into this for you and can see the activation date has been amended to 09/05/2019 due to engineer availability in your area. Apologies this was not communicated to yourself. You'll receive a further email and SMS once it's active and complete.
Regards
Re: Product Upgrade
04-05-2019 1:26 PM
Hi @abails0105
Thanks for the update
The product change route indicates that my package includes Line Rental. Is this correct as I have LRS which is due to expire shortly ?
Your current package
Re: Product Upgrade
04-05-2019 2:48 PM
Hi @rhohne
That's correct. As you are currently on Line Rental Saver the price shows including line rental, once this expires the standard £18.99 per month charge would apply unless you re-signup to another 12 month line rental saver deal. The reminder for this and the link to follow to process is here
If you need any further assistance please feel free to get in touch.
Re: Product Upgrade
10-05-2019 8:27 AM
Have been advised by @abails0105 that my upgrade should have completed yesterday. I am yet to receive any notification that this has completed. Can a staff member confirm that the upgrade has now completed.
Have rebooted router this morning and still appear to be on the old product.
Re: Product Upgrade
10-05-2019 11:41 AM - edited 10-05-2019 11:42 AM
Hi @rhohne, it looks like the order did complete on the 8th and the account updated the package accordingly.
Testing the connection suggests there is currently banding on the connection. As the connection seems to have been stable since the order completed, I've raised this with the relevant people to try and get the banding removed without going through the process of an engineer visit.
Having said this, I've checked the estimates for your line and I'm not confident that it's worth being on the higher package, as the lower package would be provisioned on (up to) 40Mbps download and (up to) 10Mbps upload:
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
Left in Jumper |
High | Low | High | Low | ||||||
VDSL Range A (Clean) | 43.7 | 30 | 7.7 | 5.5 | 26.1 | Available | -- | -- |
