Printing Bills for Business Account
- My Account/Billing
- Re: Printing Bills for Business Account
07-09-2018 10:06 AM
Has a computer wizz out there worked out how the "heckle" you can get a full print of a bill (like a business would need for accounts for submission to HM Revenue).... I get the bill displaying on the screen in a pop up which does not display the whole bill - you need to scroll up/down so when you print you get gobbledegook and because it is not all visible, you can't screen grab it?
07-09-2018 11:14 AM
I am having the same issue and would like Plusnet to introduce a 'print bill' link onto the invoice. I've managed to print a screen-shot image of the bill, but it will be a real hassle to do this every month.
07-09-2018 11:22 AM
New invoices generated by the latest billing system (introduced at the beginning of this month) are in pdf format. This should make printing much easier, you can download a copy of the bill and print it just like any other pdf.
07-09-2018 11:41 AM
Thanks for the reply, however I think I'm being thick as I still can't get a printable copy! There used to be a link to 'download PDF Bill' on the bottom of the bill. I can't see anything on the new format where I can download a PDF bill.
07-09-2018 11:45 AM
Mister W - I can't see how to do this - but I suspect the website is having a bad day. It's telling me my next bill will be in 2037!!!
07-09-2018 11:55 AM
@Elliew using Firefox, when I click on the 'last bill' hyperlink it open a pdf viewer window showing the bill. There are menu options on that viewer window to print or download.
@hymek1067 given that it seems your next bill date hasn't been set yet, has your account actually been activated yet and a bill generated ?
07-09-2018 12:04 PM
@MisterW thanks- I don't have Firefox! I've tried Chrome and Safari and neither have any menu options when I open my last bill. I'll have to see what happens next month and go from there.
07-09-2018 12:15 PM
@Elliew has your last bill actually been generated by the new billing system i.e since 1 Sept ? If not then it will not be in pdf format.
I've just tried with Chromium (don't have Chrome as I'm running Linux) and that opens a windows with download options.
Using Chrome on an Android tablet, automatically downloads the pdf an opens a pdf viewer.
07-09-2018 12:18 PM - edited 07-09-2018 12:19 PM
@Elliew The new .pdf option is only available for bills generated since the new billing system went 'live'. Previous months bills are unchanged and still in the old HTML format. HTH
Edit: Crossed with @MisterW post
07-09-2018 12:26 PM
Just bye the bye, presumably the format for invoices on business accounts is different, mine says, "This is not a VAT invoice".
07-09-2018 12:35 PM
@MisterW I think that's the answer - the bill I've tried to print is 27.08.18. So next month I should be able to generate a PDF. Thank you!
08-09-2018 12:40 PM
You're right - my bill was 28 Aug (which displays in the pop up) so not the new format - so that will explain it. I still have my next bill due in 2037 though!
10-09-2018 9:04 AM
HI @hymek1067
Thanks for coming back to us.
I've checked your billing info from our side and it's showing the year as correct, so I can only assume that this is a glitch in the member centre that will be ultimately resolved through maintenance. Everything is absolutely fine in terms of your billing and you'll receive your invoice as expected.
Best wishes,
Dave
10-09-2018 12:10 PM
I have the same issue. The bill I need to download/print is dated 19 August. Previously there has always been an option (something like) "click here for printable view" but that has now disappeared. I appreciate what people are saying about bills generated after 1 September being in pdf format but what do I do about the August one?
10-09-2018 2:04 PM
If you can send me a private message with your username I'll be happy to see what I can do.
