Plusnet Weekends pro-rata charge
Dorian182
I was recently charged £10.29 for a 'Plusnet Weekends pro-rata charge' I'm not exactly sure what this charge was for. I wasn't aware that something like this was in my price plan.
Fixes: 62
Re: Plusnet Weekends pro-rata charge
I suspect that you have only just had the phone part activated and, if this is the case, it is the proportion of the monthly line rental needed to match the billing date of the broadband package.
All billing dates are matched to the broadband billing date
Dorian182
Yes this is true. So I won't be charged this amount again?
Fixes: 62
At the future billing dates you will be charged the correct amount
Dorian182
So this amount is just an extra bit? I've already paid the £23 for my broadband and line rental. The £10 is just a one off charge?
Fixes: 62
That seems to be a bit odd
I suggest waiting for a member of staff to pick this up
Basically Line Rental is paid in advance but I don't understand why you should have been charged a full month before the service went live
Dorian182
Still waiting on staff member  Smiley
Fixes: 167
Your previous bill didn't include the line rental charge, it was higher than normal due to additional broadband usage, you should be able to view the itemised bill online. The £10.29 is exactly as Oldjim says and is the pro-rata charge for the first month of your phone service.
 Chris Parr
 Plusnet Staff
Dorian182
Okay, thank you. Smiley
