Plusnet Web Dashboard Error
thebrownjumper
I've had this issue for some time and wondered if anyone else has seen this issue?
On the home screen I see this error:
An error has occurred
You can't change your products for the moment, you have an order which is currently being processed. Please try again later.
Would be good if this is something not on my side as I've tried clearing browser cache etc.
See attachment for screen shot.
Thanks in advance.
5 REPLIES 5
Fixes: 1,600
Re: Plusnet Web Dashboard Error
I've fixed this for you now
Can you check again? Let me know if there are further issues Smiley
thebrownjumper
Anoush,
Thank you for the swift response and fixing the issue.
Would it be cheeky to ask what it was you fixed in my instance. 😊
Really appreciate the help.
Regards
Fixes: 1,600
Awesome. The initial order to transfer your services to us was still showing as partially open on our systems which was preventing any further changes from being made, so I closed the order off.
thebrownjumper
Anoush,
Fantastic - Interesting to know.
Thank you again for the very quick turn around.
Regards
Fixes: 1,600
No problem at all John
Let us know if there's anything else you'd need help with
