Plusnet Protect
tonysheff
Plusnet Protect
On Saturday I added Plusnet Connect to my account  I rec confirmation which said the download link would take up to 2hrs. I had still not rec the link on Monday, so I cancelled the add on. I see on my bill I have been charged 32p . I am not bothered about 32p. but plusnet must know I did not rec the link, so why  charge me
Fixes: 76
Re: Plusnet Protect
If you try following the "log into member centre" link at the bottom of this page you should see an option to download Plusnet Protect: https://www.plus.net/home-broadband/protect/
I hope that helps.
 Adam Walker
tonysheff
Re: Plusnet Protect
Hi Adam.
Thank You for your reply. I have now renewed my Mcafee account for 12months.
Regards Tony
