I sing the praises of Plus.net to all my potential customers, and then when they get a new account they're given a .plus.com email address. This is causing a bit of confusion between them and their contacts because the contacts then try to email them at
[email protected]. Would it be a good idea to set up a simple "check you email address should be .plus.com" auto reply to those that do this?
