Please re-open question...
- My Account/Billing
- Re: Please re-open question...
07-03-2012 8:50 PM
# 51189453 so I can reply to link:csa removed
PS: I don't have the option to close the current questions and since there are four I cannot add any new ones, hence this post
adie:red CSA name removed as per link:rules
Message 1 of 5
(1,616 Views)
4 REPLIES 4
07-03-2012 8:51 PM
Would it not be easier to add comment here, and ask the staff to create a ticket pointing to the old one.
IIRC - once a ticket is closed, its closed.
Regards
Regards
Message 2 of 5
(416 Views)
07-03-2012 9:41 PM
Well it may not be closed but I can't see it at all
Message 3 of 5
(416 Views)
07-03-2012 10:21 PM
if you 'cant see it' they normally hide older ones, you have to select the filter to pull up any old ticket numbers..
click go and the ticket IDs should appear underneath - at which point you can 'view' the closed ticket.
Regards
Regards
Message 4 of 5
(416 Views)
08-03-2012 9:04 AM
Hi Blahblah,
That question is closed - they will automatically close after 14 days have elapsed since the question is passed back to you.
I'd suggest raising a new one or leaving your query in here for the Digital Care Team to answer.
Message 5 of 5
(416 Views)
