Overcharged
hocumgday
Overcharged
Hi can someone check why I have been over charged the last 2 months. I should be paying £17 but for some reason I am. Ow being charged £21 one month and nearly £26 this month.
Thank you
Grant
5 REPLIES 5
Joshc
Re: Overcharged
Hiya
I have had a look  into the issue and found the reason for the price increase. Please take a look at this ticket (77697156) for more information. I hope this helps , please let me know if there is anything else i can help you with.
Thanks Smiley
hocumgday
Re: Overcharged
I have no idea what you mean by ticket as the number you have typed is not hyperlinked to anything.
Please advise thank you
Fixes: 395
Re: Overcharged
Hi, Tickets are another name for questions. They are viewable from your account in the member centre
Go to here http://www.plus.net/my.html?action=questions , you will need to login with your username & password, then select 'view my closed questions' and you should see the question no Joshua referred to listed.
Hope that helps
hocumgday
Re: Overcharged
I can't find anything about me being overcharged...can't someone from PN just tell me why?
Fixes: 160
Re: Overcharged
Try this - https://www.plus.net/wizard/?p=view_question&id=77697156
