Overcharged; Wrong username; Wrong Account details; Connection drops
- My Account/Billing
- Re: Overcharged; Wrong username; Wrong Account det...
20-02-2016 12:43 PM
Where to start ?
I paid the line for a full year; on 29th January I paid £19.49 even though I should have paid only £2.5SOLVED
- my username has been wrongly written so I can't use the @plusdsl.net email address
- my account details are wrong; wrong
family andfirst names.PARTIALLY SOLVED
- sometimes the connection cannot be used properly.
Message 1 of 2
(930 Views)
1 REPLY 1
Re: Overcharged; Wrong username; Wrong Account details; Connection drops
20-02-2016 3:31 PM
Hello there and welcome to the forums. I'm sorry for the issues you're experiencing. I'm happy that we've managed to rectify some of them so far.
As for your username, I apologise if our Sales team had misspelt it, however it is not possible to change this due to the way our accounts system is setup. In this circumstance, we usually close down your account and then setup a new one. From the information you've provided it appears you are online now, so this method will cause further complications with your service. However, our Customer Options Team <b>may</b> be able to perform a brand migration to move your account to a brand new account with a new username. I'd recommend giving them a quick call on 0800 013 2632. As for your email address, this would not end with "@plusdsl.net". That is just your broadband username you use when you connect to the internet. The email address format is Username@Username.plus.com
Due to our data protection process, there are only few circumstances in which we can change a name on the account. These include bereavement and name changes by deedpoll. If the name has been misspelt, we would require a letter to be posted in writing.
What sort of connection issues are you facing and have you tried raising a fault to us? You can do this online at http://faults.plus.net
I hope this helps
I hope this helps
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Message 2 of 2
(369 Views)
