Order cancelled with no explanation.
- My Account/Billing
- Order cancelled with no explanation.
06-06-2013 10:07 PM
Quote System User - Automated Script Pool
2:19pm, Thursday 6 Jun 2013
There's been a problem progressing your broadband order.
We'll get some more information on the problem and update this ticket with details as soon as we have them.
[internal note]
Order has been cancelled. Please check Install Diary and resubmit order once issue is resolved.
What? No updates either, no attempt to contact me. So it's just been cancelled like that! I got my MAC key from BE halfway through may and put in a cancellation order at the same time, so I'm worried I may actually end up without broadband now.
So I phoned up the helpline, waited 25 minutes in queue (Serious, if your websites says "However, we actively monitor our peak times to ensure we always have enough people on the phones to answer your queries without keeping you waiting too long in a queue." then try backing it up with actual people answering phones.
And what did he tell me? "Oh that's to do with provisioning, and they're closed now, I can't see anything to do with provisioning, this is just technical support".
So no help there, he can't even look for me to see what the problem is. Sigh.
I thought Plusnet had changed...
Re: Order cancelled with no explanation.
07-06-2013 1:29 PM
Sorry to see that you got this message, it does seemed to have caused you a panic. The initial order was rejected by our suppliers, so would need to resubmit an order which has now been processed.
This is committed for the 17th June 8am - 1pm.
Let me know how the install goes or if you have any questions.
07-06-2013 2:07 PM
I asked in the ticket and got no response so I phones up and waited for about 5 minutes (This page shouldn't exist if it's never going to be correct: https://www.plus.net/supportpages.html?a=212 ) to be told that would probably be the soonest possible date and there wouldn't be anything sooner (No checking, just that response)
Are you absolutely sure it can't be done sooner?
07-06-2013 2:08 PM
Quote I asked in the ticket and got no response so I phones up and waited for about 5 minutes (This page shouldn't exist if it's never going to be correct: https://www.plus.net/supportpages.html?a=212 ) to be told that would probably be the soonest possible date and there wouldn't be anything sooner (No checking, just that response)
Odd. Which options did you chose on the telephone system?
07-06-2013 2:14 PM
dick:quote
07-06-2013 2:17 PM
Sorry about the confusion on the waiting times though. I'm just going to try and see if the Order Updates queue should be included on the page or whether it's just the generic Tech/CS one.
07-06-2013 2:19 PM
Quote and put in a cancellation order at the same time
That sounds a bit worrying!. You should not have to cancel anything yourself, BE will be informed when your MAC is used. If you've cancelled directly then that could be a problem. Who is your telephone service with BTW, since if that's alos cancelled, that will cause problems.
07-06-2013 2:22 PM
I doubt that woman will say the same about my voice lol. Nevermind.
Quote from: James Hah! I'll let her know!
If there's ANY way to forward the engineer visit, I'd be okay as it appears we have the whole of next week free.
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rule]
07-06-2013 2:26 PM
07-06-2013 2:32 PM
07-06-2013 2:34 PM
They will receive notification when the service is transferred to us.
07-06-2013 2:59 PM
07-06-2013 3:24 PM
07-06-2013 3:28 PM
Quote Phone is with the Post Office,
That's good news That means there's no chance of BE cancelling the phone service once the Broadband is moved away from them.
07-06-2013 10:58 PM
But for some reason I get an error whenever I try to order it.
Quote There's been a problem. We've not been able to add Static IP to your account.
Please contact our Support Team by using the Help Assistant or calling us on 0800 432 0200 or 0345 140 0200.
