One Port Router and Millennium
- My Account/Billing
- One Port Router and Millennium
04-04-2008 4:33 PM
One of my referrals is thinking of changing from dial-up to Option 1 + Homephone Anytime. Please can someone let me know if the one-port USB/Ethernet router is compatible with ME? I need to know because the computer does not have an ethernet card and I will therefore have to connect it via USB.
Message 1 of 5
(2,472 Views)
4 REPLIES 4
Re: One Port Router and Millennium
04-04-2008 4:43 PM
To be honest for £5 you can get and fit a PCI network card and it will work fine.
Me is not one of M$ best releases and the chances of having Me/98 USB driver availability and it working well is pretty remote, and even if you could get it working it may cause more problems from a support point of view going forward.
Fit a network card and save yourself a lot of hassle.
Message 2 of 5
(765 Views)
04-04-2008 5:22 PM
Fitting an ethernet card sounds like a good idea but I am really not up to fiddling about inside computers so would have to take it to a shop. I really wouldn't know where to start.
I do know that my Voyager 105 (which PN sent when I first went onto broadband) works on Millennium because I have had it up and running on an old computer that I have so I suppose that I could probably find it and use this if necessary.
Message 3 of 5
(765 Views)
10-04-2008 9:27 AM
@poppy
You can also get USB to Ethernet dongles - like this one. Essentially it's a USB to ethernet converter and should be OK with ME.
Message 4 of 5
(765 Views)
10-04-2008 9:34 AM
It will be, I was using one on an ME system only yesterday!
(got it dirt cheap from DABS as well, though it looks slightly different to that illustration)
Message 5 of 5
(765 Views)
