No usage stats showing for 4 days now?
- My Account/Billing
- Re: No usage stats showing for 4 days now?
12-10-2015 2:55 PM
Hi
Im on Plusnet Extra Fibre which has a 120GB limit each month so I need to keep track on where my usage is at.
For the past 4 days the usage has been showing as 0kb for each of those days?
There is nothing on the service status pages to suggest there is a problem and I havent received any emails notifying me of a change or anything so just checking whats happening.
Is there a problem with the usage tracker?
Message 1 of 7
(1,060 Views)
6 REPLIES 6
12-10-2015 5:25 PM
Hi ChrisSheffield,
Thank you for raising this query to us and bringing this to our attention.
With the usage there are a couple of reasons that the usage will not show and the main cause of this is the length of your session which I can see has been on going for over 3 day's.
If you log into your router and hit disconnect and then re-connect it will reset the session for you and your usage should show then for you.
Message 2 of 7
(606 Views)
13-10-2015 8:22 AM
Words fail me!
It's nothing to do with the length of the session the vast majority of people have their usage correctly recorded with sessions measured in weeks.
The problem is that some PN gateways are borked and usage accounting doesn't work. Disconnect/connect should get you a new gateway and if you start to see usage recorded after an hour or so it will continue to be recorded no matter how long the session goes on (at least until a reconnect puts you back on one of the duff ones).
There's also a possibility of a more fundamental issue on your account, so if disconnect/connect doesn't fix it on your account more work will be needed.
People who have suffered this issue in the past and gone over their allowance as a result have had the excess charges refunded.
Message 3 of 7
(606 Views)
13-10-2015 10:37 AM
It's not the length of the session as such, it's that the session length corresponded very closely with the lack of usage on this account. Often a disconnect/reconnect will trigger these back to life.
Message 4 of 7
(606 Views)
14-10-2015 8:37 PM
Hi
I did disconnect and reconnect on my router to start a new session. The usage SINCE then has now been appearing, however I still have 3 days on my account showing up as 0kb so im still none the wiser as to where I am at.
Could I be PMed with accurate stats or something done by Plusnet staff to force an update on my account. The dodgy session is now closed obviously.
Message 5 of 7
(606 Views)
14-10-2015 9:41 PM
Don't worry about those 3 days, the CBC usage we have recorded is 0 for them and that's the data used for additional usage charges.
Message 6 of 7
(606 Views)
15-10-2015 11:48 AM
OK Thanks
Message 7 of 7
(606 Views)
