New order
Kamran
New order
Placed an order on Monday (MAC provided), since then my order status is showing "Checking your line". Is this normal? does it take this long to check line and process order?
Re: New order
If you go in to your questions area and view all the questions/service notices that may give you an indication as to where the order is, normally a question is raised for each action the system or PN take as they build the order.
http://www.plus.net/my.html?action=questions&?helpheader=questions
Otherwise hopefully someone from PN will pick this up soon!
Plusnet Alumni (retired) LinnPlusnet
Re: New order
Hi Kamran,
Sorry for the delay in your order being placed. The order has been submitted and you should receive confirmation of your transfer date in the next 24 hours.
Kamran
Re: New order
Thanks Linn. Got the line activation date. Much appreciated.
M
Re: New order
Glad that's been sorted for you Kamran. Smiley
