New 4 Port Wireless router
- My Account/Billing
- Re: New 4 Port Wireless router
11-09-2008 4:13 PM
Hi everyone,
Just a very brief note to let you know that for any signups on Option 2, 3 or Pro, from tomorrow onwards we're going to be sending out different wireless hardware.
We're going to be sending out Thomson Gateway 585v7 4 port wireless routers, which offer ease of setup, great tolerance on noisy lines and TR-069 capability. So you may get a call from one of your new referrers, wondering how to set these up.
We've sorted out a few support pages, so you'll know where to look if they need any help
http://www.plus.net/support/broadband/hardware/index.shtml
http://www.plus.net/support/broadband/hardware/t585v7.shtml
http://www.plus.net/support/hardware/thomson585web.pdf
Feel free to shout up if you have any questions!
Message 1 of 5
(2,532 Views)
4 REPLIES 4
11-09-2008 4:18 PM
Just don't try flashing the firmware tbb thread or using DMT
Message 2 of 5
(577 Views)
12-09-2008 7:07 PM
Good news - much appreciated.
Message 3 of 5
(577 Views)
12-09-2008 11:46 PM
Quote from: Oldjim Just don't try flashing the firmware tbb thread or using DMT
I've had my 4 port router for years - I've never upgraded the firmware.
If it ain't broke don't fix it.
Message 4 of 5
(577 Views)
13-09-2008 8:55 AM
Agreed. I've lost count of the number of firmware updates that have introduced new problems - Netgear (damn' good routers in all other respects) have had several dodgy firmware updates that did more harm than good.
Only update the firmware to cure a specific problem, and then check the update history first. The easiest way to bollux up a perfectly good router is to apply an unnecessary firmware update.
Message 5 of 5
(577 Views)
