Moving to Sky or Talktalk
maranello
Just out of interest, does moving from a BT line to Sky or Talktalk always incur a cessation charge, i.e. do these providers exclusively use LLU, or are there likely to be any exchanges where it is more cost-effective to lease BT lines?
My other car isn't a Ferrari
Fixes: 26
Re: Moving to Sky or Talktalk
If you move to a LLU provider, you can expect to receive a £30 cessation charge raised by BTw just because you want to leave BT's WBC network.  Note this has nothing to do with the line used - it will be the same line, just terminated differently within the exchange.
DaveyH
Seasoned Pro
Fixes: 9
Though as I've mentioned previously, I've migrated from BTw to LLU services and vice versa multiple times and never been charged a cessation fee for doing so.
Tagger
There's no cease charge provided that you are still using an Openreach line.  it doesn't matter who owns the kit at the exchange.
Which means you only pay a cease charge if you move to Virgin Media, or cease the line entirely.
Fixes: 33
@Tagger sorry, but you are wrong, a move to an LLU can mean a £30 charge.
Fixes: 461
Moving from Plusnet to Sky or TalkTalk does not necessarily always mean the cessation charge is applicable.
In some exchanges, they don't use LLU equipment.
It really all depends on the cease code that comes through to us after the service has left, that defines whether the cessation charge is applicable or not.
ghos7
ive moved to sky and you charged me a cessation charge. and im still being billed for services with you even though i left over a month ago 😆
Fixes: 186
@ghos7 - I've responded over on your other thread.
 Harry Beesley
