Moving Home
Menace65
Fixes: 4
Moving Home
I'm moving into a new place on the 1st June, my contract expires in September.
I don't know if I'll be able to keep Plusnet, as this is an Extra care home [had my left leg [above knee] amputated last october]]
Karma for being a Menace!!
Some advice please.
3 REPLIES 3
Menace65
Fixes: 4
Re: Moving Home
I move in July now, so no action needed at the moment.
Can't edit / delete a post, plusnet gets worse...
I'm sure it's some sort of social experiment.....
Alex
Fixes: 13
Re: Moving Home
Hi @Menace65
Yep I don't believe standard users can delete posts, and you can only edit your own posts if they are less than 15 minutes old I believe.
On the one hand it is a bit draconian, but on the other I see the reasoning as they have been bit before with people deciding to remove/edit their posts and it screwing up threads. One being an ex-mod.
That was a long time ago, cor I have been here a while now and live up to my forum name of a Veteran I auppose 🤔
198kHz
Fixes: 41
Re: Moving Home
@Menace65 wrote:
I don't know if I'll be able to keep Plusnet...
That would depend on the home's policy. If they allow lines to clients' rooms, Plusnet would supply one.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
