Monthly usage
IanSn
Monthly usage
I'm getting zero k on allowance used for 15th and 16th on the monthly usage page. This is certainly not correct.
Is there a glitch?
(Sorry if this is in wrong forum.)
Fixes: 62
Re: Monthly usage
it should be sorted http://usertools.plus.net/status/archive/1379335450.htm but I suggest checking again in the morning
IanSn
Re: Monthly usage
Ah, thanks. Didn't see this. Will check tomorrow.
Re: Monthly usage
Hi IanSn,
Just checked your VMBU page and there's definitely usage showing at the moment.
Re: Monthly usage
I'm pretty sure that my usage has not been right for days. There have been large (several Gb) discrepancies between my router totals and the ones on the VMBU page. Some examples:
                      Router                  VMBU
Today            1.2 Gb                    178 Mb
Monday        7.9 Gb                    1.2 Gb
Sunday          6.5 Gb                    3.2 Gb
Saturday        8.0 Gb                    3.3 Gb
Bob
IanSn
Re: Monthly usage
Thanks,
there is a gap - which shouldn't have 0 in it - over 15th - 16th - which seems to be back to normal since.
see pic attached
Coming up for end of my month and not likely to go over my limit so doesn't matter so long as its working okay now.
EDIT - not sure what VMBU is - I'm just looking at the usage page when you log-in
Fixes: 10
Re: Monthly usage
Mine is definitely wrong for Sun 15th as it is showing negligible overnight usage and none during the day.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: Monthly usage
Yep, looks like we do have some usage missing following this weekend's problems - sorry about that, we weren't aware of this at the time hence the service status message. It shouldn't affect anything and you won't be charged (of course) but we realise this isn't ideal.
Re: Monthly usage
It still seems to be wrong today though - unless it's just being very slow to update.
Bob.
Re: Monthly usage
VMBU still isn't working for me. Comparison with my router since my billing reset four days ago:
                          Router                  VMBU
Saturday          5.2 GB                    0.5 GB
Friday              3.5 GB                    0.4 GB
Thursday          3.0 GB                    1.4 GB
Wednesday      0.2 GB                    0.1 GB
The overnight usage figures look about right although I can't get an overnight/daytime split from my router. It's the daytime figures that look wrong.
Bob
Re: Monthly usage
Yesterday (Sunday's) figures:
Router  12.8 GB
VMBU    3.0 GB
Bob
Re: Monthly usage
Well, I was wondering for some reason if the router was reporting on internal traffic as well but then realised that would be silly Smiley
It seems we have a problem open on this (76497) - I'll chase that up in this morning's daily ops meeting and update you early this afternoon.
Re: Monthly usage
Any update please?
The last three days:
                          Router                  VMBU
Monday          2.9 GB                    3.1 GB
Tuesday          4.0 GB                    3.6 GB
Wednesday    7.1 GB                    0.8 GB
So Monday and Tuesday were similar but yesterday was way under reported again.
I assume that this isn't widespread as nobody else is reporting similar problems?
Bob
Re: Monthly usage
Thursday:
Router 4.2 GB
VMBU 1.3 GB
I'm going to stop posting on this now as it's not causing a problem - annoying though as I like to use VMBU to monitor our usage.
Bob
Re: Monthly usage
The problem's still open and investigations are continuing but I'm afraid there's nothing new to report as far as resolution goes.
