Monthly direct debit
plustrev
Are the monthly DD's taken in advance or in arrears.
18 REPLIES 18
Fixes: 374
Re: Monthly direct debit
You are billed in advance, the actual DD is taken slightly later.
Fixes: 472
To expand on @jab1‘s message. The DD is taken later than the billing advice but it’s still within a few days of the beginning of the billing month.
Fixes: 374
And that date is advised on the invoice.
plustrev
Thanks all.
I am leaving so want to be sure if they owe me or vice versa
Fixes: 374
How long have you go to go, and have you arranged a new ISP?
plustrev
Yes I have a new isp installed and my landline is due to be ported on Friday the 11th which I am told will cease my Plusnet account.
My contract expires on the 12th October.
Fixes: 374
OK - looks like you're sorted.
Fixes: 241
@jab1
Not entirely "sorted" - the move is too close to the billing date.  The Change Billing Date guidance states: "You'll need to do this at least seven days before your next bill is due" which infers that the "next" bill is generated well in advance of the actual billing date.
This is what will happen for a user migrating con or very shortly before the billing date...
  1. The next month will be invoiced in full at the out of contract rate
  2. Payment will be taken**
  3. When the migration completes (there is always a risk of delay) the new provider notifies Openreach, who notify Plusnet
  4. Plusnet then closes the account and marks it for final billing
  5. The final bill should be raised within 21 days
  6. Any refund due will be paid to the means by which it was taken**
**Any attempt to 'take control over' this process such as cancelling the direct debit is likely to result in further difficulties - potentially DRA or subsequently difficulties in paying any refund due.
Continuous billing protects the user from the risk of a break in service arising from the failure of the new supplier or their subcontractors.  Some of the industry's methods - dictated by Ofcom - are not overly helpful; if a user CANCELS service with their existing supplier to ensure billing stops on a given date, a new supplier cannot place orders on that line until AFTER the service is ceased ... thereby creating a window of at least 5 days without a working connection.
I suspect that there is an optimal point for ordering service from an alternative supplier for commencement BEFORE the last day of the existing service ... I would guess that is around 20 days - that allows an earliest start date 10 days before the end of the existing contract and 3 days before next bill preparation.
Fixes: 374
Fair enough, @Townman . I've been around this space long enough to know how it can easily, or unfortunately - whichever way you look at it - things can go wrong, but I was looking on the bright side, maybe not a good idea. 😉
plustrev
To jab and townman.
I realise I may have some time at the out of contract rate. (Contract end 12th)
My billing date is the 10th (tomorrow)🥴 and payment the 18th. So I think I  will be charged at the out of contract rate.
But if the cease goes ahead on the 11th the final bill should have a refund on it. Correct?
Fixes: 374
@plustrev Correct.
Fixes: 241
Hi John,
I think that the bright side here is that the user has all of their ducks lined up.
However, I am reading between the lines of the OP's OP: "Are the monthly DD's taken in advance or in arrears".  I read that as short-hand for "I have a migration date, if payment was taken in advance, I have already paid to the end of the contract and my contract with Plusnet has ended ... therefore I will NOT receive any more invoices from Plusnet / they will not take another DD".
For the reasons suggested, I do not think that the above suggested expectation is going to be met.
Broadband services migrated via the gaining provider led protocols are billed continuously by the losing provider until the migration is CONFIRMED as having HAPPENED.  That practice ensures that there are no (or minimal) breaks in service ... but that could result in a further in-advance invoice / payment which will be refunded in the account closure invoice.  Note that it is not until the new-provider / Outreach / losing-provider communication is complete will the user's account be closed / the contract be terminated.  We have seen horrible cases of that failing resulting in months of dual billing elsewhere.
FWIW I have enquired if there might be a "sweet-spot" somewhere in the last month for a migration which might avoid post contract billing and ETCs because some people might find being billed by both gaining and losing supplier for the month post migration challenging financially.
plustrev
townman
I am not migrating, I already have my new isp installed and working.
Plusnet will be ceased when my number is ported to a&a hopefully on the 11th.
Fixes: 241
@plustrev wrote:
To jab and townman.
As @jab1 states, the final bill will have the refund on it ... but what you are thinking will be the final bill and what @jab1 has in mind might not the the same as the "final" bill.  This is what I expect will happen...
  • Tomorrow's bill will be the advanced charge for 10th Oct to 9th Nov at the out of contract rate
  • The DD taken around the 18th will be for the amount invoiced
  • If the migration is successful around the 12th Oct (that includes proper communication of the migration) the final bill should be raised around the 2nd Nov - it should show a credit for day of migration + to 9th Nov
  • That will be paid back by the payment method (DD ?) if that authority is still in place
  • If the method is DD and the DD has been cancelled, refund will be via a cheque ... and that can take substantially longer
