Monitoring broadband usage
- My Account/Billing
- Re: Monitoring broadband usage
07-05-2011 4:15 PM
I seem to have overshot my 60GB usage limit despite scheduling most activity to take place between 12:15 am and 7:45 am. Is there a way to get more detailed breakdowns of where exactly the usage is highest?
As far as I can tell (this is rough estimate, unfortunately) I could not possibly have used more than about 35 to 45GB this month.
Mukesh
Mukesh
Message 1 of 6
(1,317 Views)
5 REPLIES 5
07-05-2011 6:20 PM
No replies, yet, but I was wondering if anyone knows when the meter resets to zero on my usage allowance? I would like to monitor my usage and check against PLusnet's usage indicator just to make sure that they correspond.
Thanks?
Thanks?
Message 2 of 6
(594 Views)
07-05-2011 6:29 PM
Usage is reset to zero early in the day on your billing date.
Note also that the recorded usage comprises downstream and upstream data.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 3 of 6
(594 Views)
08-05-2011 12:08 PM
thank you for the reply. the offpeak times that plus net mention; are they from 12 midnight to 8am UK time?
adie:quote
adie:quote
Message 4 of 6
(594 Views)
08-05-2011 1:06 PM
yes indeed, if you look at the VMBU by clicking the bottom left link on this page you will see that it split the usage and tells you the time zone (some old packages have midnight to 4 pm free)
Message 5 of 6
(594 Views)
17-05-2011 1:11 PM
Quote Is there a way to get more detailed breakdowns of where exactly the usage is highest?
clicking on "usage history" and "internet activities" on our" view my usage" page should give you more detailed data
Otherwise you could try some network monitoring software such as this: http://www.softperfect.com/products/networx/
Message 6 of 6
(594 Views)
