Mobile minutes
Mayfly
Mobile minutes
Does anyone use the mobile call plan?
I'm wondering if it's the way PN set out their bills or if they have my mother down as owing 78p as well as taking the the £3.00. I know there's no way my mother has used 100 minutes of mobile in 2 weeks.
Fixes: 229
Re: Mobile minutes
If you can PM me your mothers username I should be able to take a look
 Matthew Wheeler
Mayfly
Re: Mobile minutes
Have done Matt - thanks
Mayfly
Re: Mobile minutes
I raised tickets and received a reply this morning stating it looks like the account is wrongly being charged and it is now on hold until the 16th allow the next invoice to be generated so a refund can be given.
Seeing as the next invoice isn't due until the 15th why can't the calls be taken off so the account isn't charged for those calls in the first place?
It isn't problem doing it your way but it just appears to me that you are generating twice the amount or work you need too.
Fixes: 5
Re: Mobile minutes
Can you post your ticket number please? With that, I can advise further. Thanks.
 Tony T
Mayfly
Re: Mobile minutes
Hi Tony
Ticket number 100428097
Fixes: 5
Re: Mobile minutes
I see what they've done!!!
Because we've raised a task to prevent this happening again, we cannot confirm that you won't be charged between now and your invoice date. We're therefore going to refund all in one go once we're sure how much is owed, rather than removing it from the invoice now, and having another bill occur between now and then.
I trust that clarifies, and apologies for the problem and confusion.
 Tony T
Mayfly
Re: Mobile minutes
OK thank you for the clarification,
Mayfly
Re: Mobile minutes
Can someone take another look at ticket 100428097 for me please - it was placed on hold on 9th March came off hold and placed back on 2 days later, came off hold again last Thursday 26th but I haven't heard a dicky bird since.
My mother is still being charged for mobile calls.
KatC
Re: Mobile minutes
Just had a look into this for you and the team are still working on rectifying the problem. In the meantime the ticket will remain open with the billing team so we can look to refund any overpayment made which should be included in the plan. Sorry for any inconvenience caused.
Mayfly
Re: Mobile minutes
Thanks Kat I see 3 hours after I posted here the ticket was updated and put on hold agian.
Fixes: 5
Re: Mobile minutes
Yes, it's been put on hold until the payment clears so that we can refund it, and so that we can continue to chase our network team for you.
 Tony T
Mayfly
Re: Mobile minutes
So it's been put on hold yet again!
This is ridiculous almost 2 mths to sort.
Please tell what exactly are you doing PN to rectify this problem or are just letting it run. I haven't seen anyone else say they have a problem can't you cancel the 100 mobile minutes add on and re apply it?
MattyC
Champion
Fixes: 46
Re: Mobile minutes
Hi Mayfly,
I'm really sorry that it took this long to resolve. Have fed this back to our billing team.
Mayfly
Re: Mobile minutes
Hey PN I just inadvertently hit the wrong button and closed the ticket - grrrrrr can you re-open it or do I need to raise another?
Basically I received an email that says the billing on the account is broken and you will keep an eye on it and reimburse any over charges in the future.
Not good enough I'm afraid, my mother does not bank with you!  It's not the amount involved it's only a couple of quid, it's the fact there is a problem and you aren't sorting it and I have enough on my plate without having to check that you have made refunds.
I asked before why can you not cancel all payment details and set them up again? Whilst I personally have never had a problem with you it does appear that on this occasion with my mothers account your billing is not fit for purpose.
