Manage account portal cant change add products
nufclad147
Hi looking in my account portal under manage account tabs I notice a large yellow banner which states
An error has occurred
You can't change your products for the moment, you have an order which is currently being processed. Please try again later.
As it stands at the moment I'm unable to add bolt on or add remove BT sports App products. Not that I want to remove BT sport app product but would like to have functionality to add remove features as when required which at the moment it was seem I am frozen out of.
I do not believe I have any outstanding product changes in the system I joined Plusnet in June an added BTsports app product almost 2 months ago now.
Any help in understanding why this banner is apparent on my account portal and if it can be removed.
Many thanks for your help.
4 REPLIES 4
wakeman
Re: Manage account portal cant change add products
hi @nufclad147
Sadly this is seemingly a common problem with their website software, I have had it several times, it seems to occur anytime you change something, the sites gets stuck in this message.
Hopefully a PlusNet Staffer will come along and fix it.
nufclad147
Bump Been a while and the banner is still visible in my manage account page. No one really come forward with powers to sort this for me. I may give it another week then try live chat or if avail quick call
jgb
Champion
Fixes: 22
@nufclad147
Live chat no longer exists despite some links on the Plusnet website (if anything they only link to a sales bot).  It was withdrawn by Plusnet many months ago.
nufclad147
gave the call centre a buzz an they sorted it.. many thanks for the replies
