Madasafish
PaulDickens
Madasafish
Hi. I am a PlusNet user. I also help to run a charity which had a Freenetname website and email account, which transferred to Madasafish and then to PlusNet. It has all worked well for ages, but recently I wanted to set up some new email addresses and found I can't log in to the PlusNet Members Centre. I am using the same username and password that I use successfully to log in to my email so I know they are correct. About 3 weeks ago, online chat said there was a technical problem which would be resolved in 2 weeks. When is this problem likely to be sorted please?
Paul
9 REPLIES 9
MatthewWheeler
Fixes: 405
Re: Madasafish
Hi there.
To do this you'll need to log into the Madasafish website rather than ours.
You can do this by going here
 Matthew Wheeler
PaulDickens
Re: Madasafish
Thanks for your reply.
I tried that but I'm afraid that doesn't work.
spraxyt
Fixes: 75
Re: Madasafish
The Madasafish homepage does not appear to support secure https connections. If you follow the basic http link http://www.madasafish.com/ then go to My Account you are directed to the secure page https://secure.madasafish.com/myaccountdx/summary/ where, based on what Matthew said, you should be able to login. Smiley
David
PaulDickens
Re: Madasafish
I am really sorry but that is precisely what I tried following Matthew's advice. I have now tried it again but there are no options to add email addresses.
Thanks for your help. I think I am going to have to change supplier.
Paul
MatthewWheeler
Fixes: 405
Re: Madasafish
Can you PM me the username of the account in question?
 Matthew Wheeler
PaulDickens
Re: Madasafish
Sorry Matthew - I must be being thick but I can't immediately see how to PM you.
SpendLessTime
Aspiring Hero
Fixes: 82
Re: Madasafish
@PaulDickens
Click on the pink MatthewWheeler text in the top of Matthew's post then scroll down the resultant page to the "Contact Me" section and click on "Send Private Message"
PaulDickens
Re: Madasafish
Thanks. I tried that, thinking that it must surely be the way to go. I even found the "Contact me" section, but there is definitely no "Send Private Message" option and no hyperlink associated with the "Contact me" part. Can't imagine it makes any difference but I'm using Google Chrome
PaulDickens
Re: Madasafish
Forget that last post. For some reason the Send private Message has just appeared. Thanks for your help
