Madasafish Acquired by PlusNet - Not fit for service !!
brinzlee
Thank You for taking over the Madasafish Email accounts. I have to say though we really do feel like the poor relation. Our system is so basic we have no encryption on any of the email accounts and would have thought the transition to Plusnet would have included a much more professional front end like that which is offered to the Plusnet customers.
I have had my email address for many years and want to retain it otherwise I would have changed to the free email services which provide a much more secure end to end encryption.
The service I'm paying for is not free so it there something that can be done about this in the form of upgrading the rather shoddy totalise server ?
Kind regards
Gildersleeve
Re: Madasafish Acquired by PlusNet - Not fit for service !!
Wow, that brings back some memories....before I joined Plusnet years ago...I was with Madasafish. It seems eons ago.
Plusnet Staff
Plusnet Staff
Fixes: 115
Hello there. I'm sorry to hear that you're not happy with your Madasafish email service. As the Madasafish servers use a different mail system compared to Plusnet, we're unable to migrate it across on to the Plusnet system. Furthermore, neither the Plusnet nor Madasafish servers currently support end to end SSL encryption. At the moment, they rely on authenticating using your password.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
Fixes: 69
It doesn't address the SSL aspect, but you can log into Plusnet Webmail using your Totalise address.
Plusnet Products Team
brinzlee
I tried to login to the PlusNet portal but it didn't work.....which pull down tab do I have to select as service provider, as totalise isn't presented.
Kind regards
Fixes: 69
Odd, it should work just using the default (Plusnet) and your full email address as the username) Huh
brinzlee
It doesn't appear to work using this portal
https://www.plus.net/index_portal.html
I am however more concerned with the lack of encryption on password authentication knowing how easy it is to monitor and hijack with man in the middle attacks....or in public places with wifi.
Plusnet Staff
Plusnet Staff
Fixes: 159
You won't be able to log in to the Plusnet website, only the webmail. https://webmail.plus.net
 Chris Parr
 Plusnet Staff
