MAC code from BT - dragging heels
- My Account/Billing
- Re: MAC code from BT - dragging heels
05-09-2014 11:13 AM
05-09-2014 11:25 AM
OFCOM rules are that it has to be provided in 5 working days
05-09-2014 11:27 AM
If they're not meeting that then tell them you will contact Ofcom.
Edit: sorry if I repeated what you said Jim, it advised me there was a new post but didn't show me it!! so I posted anyway.
05-09-2014 11:28 AM
05-09-2014 11:36 AM
Quote from: pb123 I have just signed up to Plusnet. I can not progress my order without a MAC code from BT. Even though my account with them is completely up to date, they are quoting 7 - 10 days by email in order to obtain this MAC code to migrate from BT(BT wholesale) To Plusnet(BT wholesale).... How do I or can I expedite this?
I asked BT for my MAC on the 23/8/14 and they said it would take 5 days via email. Five days came and went so I called them, they said that it had been sent!!! I told them that it hadn't so they gave it me over the phone there and then.
AFTER I had used it to sign up with Plusnet they sent it me via email....twice!
Use this number to call them, it's a UK based call centre so you will get it straight away: 01324 452504 (It's there special offers line predominantly, but they'll sort you out). This shows you the area code so you will not get stung for a peak rate number http://www.area-codes.org.uk/01324.php
05-09-2014 11:43 AM
05-09-2014 12:08 PM
05-09-2014 12:17 PM
No T in my name though
05-09-2014 12:34 PM
The MAC code has been rejected by Plusnet saying its expired even though it was only (supposedly) generated yesterday. I called BT again (01324...) and after much enquiry told me its because "Plusnet have not made an Advice of Transfer to them...." !?? what does this mean - cant get through to Plusnet customer services but thats another story...
05-09-2014 1:22 PM
Are you ok to PM the MAC key to me? The specification of it should be:
4 letters, 8 numbers, a forward slash, 2 letters, 2 numbers, 1 letter. For example: LLLL12345678/LL90L.
If it's fine or just needs a minor tweak then I may be able to place your order straight away.
Matty
05-09-2014 2:03 PM
05-09-2014 2:33 PM
Really sorry to be the bearer of bad news pb123. Chances are you will need to run it past BT again.
05-09-2014 2:40 PM
Sounds like BT are giving you the run around. I would guess that the 'Advice of Transfer' is what gets sent to them (by Btw?) when PlusNet use the MAC. However if the MAC is invalid/expired then they can't use it. MAC codes will expire if not used for 30 days I believe.
Quote called BT again (01324...) and after much enquiry told me its because "Plusnet have not made an Advice of Transfer to them...." !?? what does this mean
05-09-2014 3:56 PM
05-09-2014 4:02 PM
