Loging in and out - Is this how it is meant to work?
SoFarSoGood
Fixes: 5
Hi
If I login to my BB account via the Welcome Back screen and then logout, the screen goes back to the Welcome Back screen (as expected).
However, if I bypass the Welcome Back screen login and click on Broadband, phone & TV under My Account, I am taken back in to my account Home screen without needing to re-enter my Username or Password.
I can stop this happening by closing my Browse (FF) and re- opening.
Note: My Browser is set up to delete all cookies on exit.
Thanks for your help.
Regards
5 REPLIES 5
daveplus
Fixes: 10
Re: Loging in and out - Is this how it is meant to work?
I doubt it very much. Logout means logout everywhere else in the universe.
PS it does the same for me
SoFarSoGood
Fixes: 5
Hi daveplus
I agree.
If it does the same for you then Plusnet need to check this out ASAP and confirm it is not a security issue.
Thanks for your reply.
Jonpe
Fixes: 9
Like Brexit once meant Brexit, now we're not so sure. Laugh
JonoH
Fixes: 153
Hi, sorry for the inconvenience. We're aware of the issue and currently have a fix in testing. If all goes well that should be live by the end of next week.
 Jono H
 Plusnet Community Manager
SoFarSoGood
Fixes: 5
Hi JonoH
Thank you for the update.
