Listed Phonecalls In Bills
Francesca
Dear PlusNet,
How do I get both billed and unbilled calls showing on my bill statements please?
I would like to see numbers I have called showing on my bill statement whether I have been charged for them or not.
I had that with my last provider.
Many thanks.
10 REPLIES 10
Legend
Fixes: 255
Re: Listed Phonecalls In Bills
@Francesca 'Freephone' numbers are never shown on Plusnet invoices, and the system cannot list them - that's is the way the system has been ever since I've been here (9 years) and probably before.
Fixes: 395
but other non-charged ( e.g plusnet to plusnet ) calls are shown in the billed calls list.
@Francesca  are you confusing billed with chargeable ?
The billed calls list are those calls which have been included in the last monthly bill, whether chargeable or not. Unbilled calls are those made since the last bill
Legend
Fixes: 255
@MisterW I find it strange too, but obviously the PN system ignores calls where the recipient pays. As you say though, PN>PN calls are listed, but as zero value.
Fixes: 395
I think it's more basic than that, I don't think the Openreach/BTw system sends charging information for those calls
Legend
Fixes: 255
Makes sense, @MisterW Smiley
Francesca
I do not get either of them listed in my bills.
What I get are bill summaries like Line Rental, Voicemail and Payment in the 'Your Charges Broken Down' section.
Legend
Fixes: 255
Thought you had sorted it as you didn't reply for a couple of months, @Francesca . Your calls are listed on page 3 of your invoice.
Fixes: 1,600
Hi @Francesca
I'm afraid you'll only see a list of calls on your bills if you've been charged for the calls. However you should be able to view a list of all calls you've made regardless by clicking on the view unbilled calls or view billed calls button from Here.
I hope this helps.
Legend
Fixes: 255
Are you sure, @Gandalf ?
Fixes: 1,600
I stand corrected. Cheers for the double check @jab1
@Francesca If there's no calls showing on your bill then you wouldn't have made any Smiley
