Line Rental Saver
LRB124
Line Rental Saver
I renewed my Line Rental Saver in August 2019 and I am thinking of leaving Plusnet to go to another provider. Please can you advise me as to whether I will get a refund on the months left of my Line Rental Saver should I transfer to another provider?
5 REPLIES 5
Fixes: 400
Re: Line Rental Saver
@LRB124
If you read the terms and conditions you will find that you have 14 days to cancel after which it is non refundable.
jgb
Champion
Fixes: 22
@LRB124
What @Baldrick1  says is the normal position, but I believe that you do get a refund of the unused portion of the LRS if you are leaving due to a price increase that affects you AND you advise Plusnet that is reason that you are leaving within 30 days (??) of the notification of the price increase to you by Plusnet.
Fixes: 400
@jgb
I'm not sure about this with respect to the December increase. The broadband price is not increasing. With LRS in place it's only calls packages that are going up and I've a feeling that this does not count.
Fixes: 1,586
Thanks for getting in touch @LRB124 I'm sorry to see you're looking to leave us.
The above advice is correct in that line rental saver is refundable in the following situations:
  • You cancel line rental saver within 14 days starting from the day after you buy it
  • We make a detrimental change to your broadband or line rental subscription fees i.e. you're not on a fixed price contract. If that's the case, you'd need to call our customer options team on 0800 013 2632 within 30 days of receiving an email about the price refresh/increase to let us know you'd like to leave because of this
Having said that I'm sure we'd be able to tempt you with a new deal to keep you as a customer if you call customer options.
I hope this helps.
jgb
Champion
Fixes: 22
@Baldrick1
Yes, I could have explained that better but @Gandalf  has now set things straight.
