Limit nearly reached
- My Account/Billing
- Re: Limit nearly reached
29-11-2013 2:27 PM
Don't know if it's possible to ask the question on here, but there is such a long waiting time on the phones, so I'll give it a go. I received an email to say I have nearly reached the 10GB limit on my PlusNet value account. I want to cap it at 10GB and I think I've done this via the website but I would be grateful if it could be checked. Also will I still be able to use the 12 to 8am for free. It's never happened before, I am blaming my dad for downloading sat nav stuff.
Thanks in advance.
Thanks in advance.
Message 1 of 4
(655 Views)
3 REPLIES 3
29-11-2013 3:48 PM
Your limit is set, so you won't get any extra usage charges. Your service will be slowed down though and that's 24/7 until usage resets, so I'm afraid even off peak it's still limited.
Message 2 of 4
(341 Views)
29-11-2013 5:14 PM
Thanks Matt, does that mean that I'll still be able to access some sites even though it will be slow or will it get cut off altogether.
Message 3 of 4
(341 Views)
29-11-2013 5:22 PM
You should be able to access any site, just at a very reduced speed - iirc it's around 256kb/s
Message 4 of 4
(341 Views)
