Leaving
dennisb66
Leaving
Hi everyone,my years with Plusnet have been great, however it's now time to leave. Cry    Because I spend the summer months at my caravan I have decided to go  3 MiFi, in fact I'm using MiFi at the moment.
    Can i please be advised how I cancel my broadband AND phone.
Thank you
Dennis
Mattz0r
Re: Leaving
Just give the Customer Options Team a call on 0845 140 6002 - Select the option for "Thinking of leaving" - They're available Monday to Friday 9am to 8pm and Saturdays 9am to 5:30pm
Cheers,
Matt
dennisb66
Re: Leaving
Thanks Matt, have now cancelled. CryWould have been nice if plusnet had MiFi)
Mattz0r
Re: Leaving
No worries - And people on here moan that it's so hard to cancel....
This shows that it's not!
Fixes: 78
Re: Leaving
Sorry to hear you're leaving dennisb66!
 Adam Walker
NorthEasterner
Re: Leaving
Quote from: Mattz0r
They tried to keep me by interrogating me.  Are your staff after commission PN?
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 62
Re: Leaving
That is a part of their job
scoobydoo1
Re: Leaving
Quote from: NorthEasterner
Quote from: Mattz0r
its a last ditch attempt to keep you by (normally offering you a discount or maybe a better deal than your moving too)
pwatson
Re: Leaving
If you're definitely wanting to leave I've found the best technique is to say you're emigrating when you call in.  Saves a lot of time... Smiley
Of course, this won't work if you want a MAC!!
saif1a
Re: Leaving
Please can someone advise why my Broadband and phone with PlusNet is still continuing while my start date with TalkTalk has already started on 20-21st August 2013. It suggests to me, I will be billed from both companies.
Surely Talk Talk has communicated my start date and PlusNet should have closed my line so I can put the other router in place and also commence the telephone service with TalkTalk. I have tested the Talk Talk router and it is active and working.
Please can someone tell me how to get through to PlusNet to amend my billing to reflect the actual cut off date as communicated between TalkTalk and PlusNet. Recently their customer service takes 20-40 minutes to connect. I have tried many different times of day and could not get response in the time stated by automated response. My wireless phone battery dies before I can get any response.
I've tried calling the new customer line and they respond within a few mins.
From my experience over the years, IT REALLY IS DIFFICULT TO LEAVE. MEANWHILE THEY MAKE THE MONEY THEY IGNORE YOUR MESSAGES AND CALLS FOR HELP.
Fixes: 62
Re: Leaving
Duplicate post in another thread removed
Note that TalkTalk are not responsible for advising Plusnet - it is supposed to be automatic with notification by BT Openreach but it sometimes goes adrift
I suggest raising a ticket here https://www.plus.net/wizard/?p=wizard&page=22236&wizard_id=38 advising the date your connection with TalkTalk went live (router connects and works)
As a point - now that TalkTalk is live your Plusnet broadband won't work BUT as the Plusnet router uses TR-069 to auto configure as do TalkTalk you may find the the Plusnet router has been configured to connect to TalkTalk
Fixes: 61
Re: Oh you want to cancel eh, we will make that very expensive for you!
Its not possible to have Broadband (or phone) service on one line from two companies at the same time. If your PlusNet router still connects then your service is still with them, if it doesn't and the TT router connects then your service has migrated. As to billing, well that's a different matter, if your service has migrated to TT and they haven't confirmed that, then PlusNet may still think they are supplying it.
AFAIK that can't happen, the PlusNet router is configured to talk to the PlusNet TR-069 server so there's no way it's going to get any TT details...
Fixes: 62
Re: Leaving
As  I said in my PM that isn't necessarily correct
I had a Plusnet supplied Dlink router with the Plusnet TR069 and it not only worked on TalkTalk but set itself up automatically when I loaned it to a friend to help with diagnosis of a problem
Talking to staff here about it the opinion was that TalkTalk only looked at the line which the router connected to and activated the router as the TR069 isn't specific to Plusnet. Note that Plusnet look at the line and the router serial number I believe
Fixes: 61
Re: Leaving
I guess that's typical of TT then, assume if its on our network, it's one of ours and don't bother to authenticate it! Roll eyes
Re: Leaving
Maybe not quite that simple but I believe that if a line is connected to their network and enabled for broadband then, subject to verifying the account (via identification of the line rather than any login), it will connect (I don't like TT but this seems a simple and sensible approach).
Call me 'w23'
