Leaving PlusNet, do my bills stop automatically?
chrisisbd
I'm leaving PlusNet after many years.  It's not because of bad service or anything but we have CityFibre FTTP now (which PlusNet can't provide) so I need to cease the PlusNet FTTC.
I have moved the old FTTC 'landline' number to a VOIP provider and that has just started working with the FTTP so the old PlusNet landline no longer works (I've checked).
So, is that all I have to do?  Will PlusNet stop taking money from me?  My last bill was dated October 25th so presumably I will get a few days pro-rata charge and that should be it.  I've been out of contract for quite a while.
9 REPLIES 9
Fixes: 577
Re: Leaving PlusNet, do my bills stop automatically?
Have you not received a 'sorry you are leaving' message from Plusnet ?
Fixes: 244
@chrisisbd
It should pan out like this...
  • You request the move your telephone number elsewhere
  • That should give rise to a "sorry you are leaving" anti-slamming email from Plusnet
  • The number is then moved
  • That should trigger the closer of the account (and cease of the old broadband) and all associated services, including email if you have it
  • 20 days later you should receive a final invoice - either a refund or residual charge
chrisisbd
I've not go any E-Mail from PlusNet yet but the number only transferred to VOIP today.
Fixes: 577
@chrisisbd you should have had a 'soory you are leaving' once the request to port went in!
Use the 'PN Tickets' link in @Townman s post to check your account for 'closed questions' . If there's nothing then call support to check.
Did you use the OTS (One touch switch) system to request the number port ?
chrisisbd
The request to port the line was done by my new VOIP provider as part of setting up the VOIP.  All I had to do was provide them with details of my PlusNet account and sign a form saying 'yes, please let XXX have my number'.
chrisisbd
The 'PN Tickets' link doesn't work for me, I get a 'Not Found' error.  It's probably because it links via a tracking site and I have a blacklist of such sites in my DNS server.
Fixes: 577
In that case try this directly https://www.plus.net/member-centre/login?p=search&view_by=30days
Sounds like they may not have used the OTS system, not sure why ? I thought all suppliers were meant to use it as it handles all the notifications automatically. Nevertheless porting the number should still have notified Plusnet
chrisisbd
Thanks for the link, no outstanding tickets/messages there.
I guess I had better phone support to check things.
Fixes: 244
@MisterW
That link did not work for me - this did https://portal.plus.net/wizard/?p=search&view_by=30days
@chrisisbd
Thank you for the feedback - I have modified the link in my signature.  That is a hang-out from the old forum platform which had a very stringent restriction on the size of the signature content pay load (irrespective rendering).  The consequential need for tiny URLs is thus no more!
