LRS not an option when upgrading online for existing customers ?
FIXED- Subscribe to RSS Feed
- My Account/Billing
- LRS not an option when upgrading online for existi...
29-06-2017 11:35 AM - edited 29-06-2017 11:36 AM
Hi - I'm currently on 17MB PlusNet Unlimited (no phone package) and I'm considering upgrading to Unlimited Fibre Extra with a phone package, so I did a 'dummy run' online via the Member's Centre to find out the cost and noticed there is no option to select Line Rental Saver when choosing the phone package.
Is this not possible ?
Fixed! Go to the fix.
Re: LRS not an option when upgrading online for existing customers ?
29-06-2017 11:53 AM
If you phone up customer options you will probably get a better deal than upgrading through the member centre, and probably be able to take up LRS at the same time.
29-06-2017 2:28 PM
I believe if you'd like to process the product change online yourself, you'll need to select the monthly line rental option.
Once your line is transferred to Plusnet, you'll then be able to go www.plus.net/rentalsaver to pay LRS which will take effect for month after. Appreciate it's not a brilliantly designed system.
Having said that...
...this is probably my suggestion too.
If you call Customer Options on 0800 013 2632 (Selecting Option 1 then Option 2), we should be able to offer you a more competitive deal for Fibre Extra with Home Phone, and we'll be able to start your LRS from day 1.
There's currently no wait time to get through to that department. Alternatively, we could arrange a call back from them?
Anoush
29-06-2017 7:53 PM
I wanted to renew my LRS on line last week but couldn't find where to do it and ended up phoning.
30-06-2017 1:57 AM
04-07-2017 6:48 PM
Anoush
I did as you suggested and got offered an absolutely cracking deal - thanks !
04-07-2017 6:51 PM
Great suggestion - thanks ! I only made Gandalf's reply the 'fix', as it contains the phone number for anyone else wanting to do the same
04-07-2017 8:32 PM
