Is my Premium productt now an 'up to 20' connection?
kentmere
Hello
I upgraded to the Premium product in February 2010 and noted that I would be informed about when our connection would be moved to the ‘up to 20Mbps’ band, following changes at the local exchange. These changes seem to have happened by the end of April because a friend of mine who lives a few yards away (also having also upgraded to Premium) was informed that his service would be moved to ‘up to 20Mbps’ within a short time.  He now sees max download speeds of about 15Mbps. However, I haven’t been informed about this change and although my connection is now very stable after wiring amendments here, I usually see a max speed of 6.5Mbps, my Thompson router syncing at about 8.5Mbps.  I am assuming that I am still on an ‘up to 8’ connection.  See data below:
DSL Connection (07.09.2010)
Link Information
Uptime: 27 days, 9:40:05
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 8,558
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 8.00
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 23.5 / 41.5
SN Margin (Up/Down) [dB]: 26.5 / 8.0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 236 / 0
FEC Errors (Up/Down): NA / 16,921,242
CRC Errors (Up/Down): NA / 21,478
HEC Errors (Up/Down): 0 / 18,133
I would be grateful if you would check on my connection to see if it is possible (or wise) for it to be moved to the ‘up to 20 band’.  I hope that the above router data might indicate that such a move would be of benefit.
Kentmere
Fixes: 57
Re: Is my Premium productt now an 'up to 20' connection?
You are on the up to 20 band as otherwise you wouldn't have a sync speed of 8558 kbps although the upstream hasn't been unlocked if that is a concern
The 'DSL Type' is the key here, G.992.5 is ADSL2+, G.992.3 is ADSL2, G.992.1 is ADSL1.
kentmere
Ok, thanks for replies.
Kentmere Smiley
